BakFlip
This is the URL (I think): http://www.bakliner.com/g2.htm
- Jack
I've had to re-align mine once or twice for the latches. Give that a try, it only takes a minute.
Do you open and close it with care or are you one of those that just use it without any type of regards what-so-ever?
edit: truck looks great, love the beefy tires you are running.
^^^ thanks
and yes i do open and close it like it is meant to be i dont abuse it or anything. and ive tried the re-alignment and it still does it. when i get some time im going to fab something up to fix the problem. probably shims between the latch itself and the cover if you can picture what i mean. i might even fab up some metal latches to replace the crappy plastic ones. and i want to seal it all with some silicone or something. i really like the looks and the design has potential but its made so cheap.
But wow what a gorgeous color combo. That is probably my favorite. Nice rides.
I don't have a KR but I've had the Bakflip G2 on my Lariat for about 15 months now without a spec of trouble. I love it. I too have had to realign it once or twice after having it folded up for some time -like carrying the golf cart cross country for 3-4 days. Otherwise it's been great and the only leaking has been very, very, very minimal right around the tailgate.
I recently added a Roush spoiler and the rubber lip of the G2 lays right up on it making a very nice seal. Prior to that Ihad considered maybe adding a piece of weather stripping to the underside of that lip to make things a bit more watertight, but now I don't think it's necessary.
A thumbs up for the Bakflip G2.
I`ve Had a 1st gen for about a year now(funny how they came out with the 2nd gen. a week later) biggest POS I`ve ever bought. Might as well not even have a top on it`s leaks so bad. Ruined alot of tools! Latch system is a joke.
I've got the G2 Bakflip as well, and have had no issues what so ever. Great tonneau cover as far as I consider. The odd little bit of water by the tailgate, but everything else is great.
When putting in the tubes for the front drain, I used a hole saw to drill into the rubber plugs that are in the front of the box. It made a nice clean install of the drain hose, compared to just using a blade a making an X shape for the tube to slide into.
Best accessory that I've gotten yet....
