King Ranch
My KR sound like airplane at 45 mph??
Old Jan 6, 2008 | 01:51 AM
svermill's Avatar
Originally Posted by becerraale
you don"t think is something in the trans.??
Truthfully, they're just way too complicated for me to even think of messing with them anymore. I was a gearhead in my youth and even did a year-long stint as an auto body apprentice in high school. But I haven't picked up a wrench and used it against a vehicle in years. My only remaining advice would definitely be to see a mechanic. Others have already suggested some of the other forums, which is a good idea because lots of Ford mechanics lurk in some of those and they are really knowledgeable and they are really helpful. Naturally, this falls under the "sooner the better" repair category. Even though you're only hearing it at a given speed doesn't mean there isn't something going on at all speeds. Hope it doesn't turn out to be expensive for you. You never know, it could be something pretty minor that's causing you all this angst. Git 'er fixed and off yer mind. That's what I'd do.
Sorry, that's all I got...
Old Jan 7, 2008 | 10:05 PM
MusicMan's Avatar
I saw the responses you got on the transmission forum, so I figured I'd drop this comment over here.
Ever since I got my truck (I've got an '03 KR), I've had a noise at similar speeds. It seems to get louder as I run 45-50, then it suddenly goes away as I get over 50. I suppose there could be a harmonic frequency (if you've never heard the term, think of that video of the Verrazano Narrows bridge collapse which is an extreme example) the truck goes through, but I've never felt any vibration associated with the noise. I'm inclined to think it's just some sort or road noise and have given up on finding it. I've got over 91k on mine now so it hasn't been a problem yet.
Old Jan 8, 2008 | 01:12 AM
Herman_Z's Avatar
I believe that the Verrazano bridge never did collapse and is still up and well... and that the Tacoma Narrows one collapsed in 1940 due to wind-induced mechanical resonance....?
Z-man
Old Jan 8, 2008 | 07:40 AM
bbrinn's Avatar
Drive Train Noise
I have been paying close attention since I first saw your note.
My KR is new to me in September 2007 and I too have been concerned about what I would describe as a drive train noise and late shift point.
I have a 2WD Chevy 2500 work truck and it seems to get into overdrive much sooner that my 4WD KR F150. The shift points also seem to be later and longer in the KR, contributing to the "wherrring" drive train noise.
Maybe we are describing the same situation.
I am a very gentle driver. I tend to accelerate slowly and evenly. Perhaps if I were more aggressive the transmission would respond differently - I will try it and keep notes.
I also seem to recall something about Ford power train control modules learning driver habits. If anyone could weigh in on that,it would be good info.
Anyway.....I cannot offer a conclusion but I am scheduled to buy some new F250 work trucks. I will keep you posted on the test drives.
Best regards,
Bill
Old Jan 12, 2008 | 09:38 AM
MusicMan's Avatar
Sorry Z-man.....I never lived out there so I forgot the bridge name. The wind began the oscillations which eventually hit a frequency that caused it to get worse and worse.
After I first posted, I also remember coming across a myth-busters segment once where they took some sort of actuators and basically created a hammering motion against one area of the bridge. When they hit the right frequency, they were able to feel the vibration about half-way across the bridge.
Old Jan 12, 2008 | 10:46 AM
RollingRock's Avatar
I already change the wheels ,I have three sets of rims w/tires 18" the originals ,20" crome wheels and 17" I like the 17"s looks very sport ,https://www.f150online.com/galleries...138&anum=15446 I try all of them but,you don"t think is something in the trans.??
I suspect its a drive shaft issue or the rear diff is out of alignment.
does it whine at those speeds?
Old Jan 15, 2008 | 01:08 AM
becerraale's Avatar
Talking
Yea you can ear it @ 43 to 45 mph w/ no vibrations Farmers B. TXI cross Keller last weekend to Halmton City 114Hwy to 377 nice place
Old Jan 15, 2008 | 01:14 AM
Yea you can ear it @ 43 to 45 w/ no vibrations Farmers B. TX
I am almost 90% sure that your rear dif is out of alignment. Its a very simple fix to shim the gears to proper alignment. I had the same prob with my 04. Took them about 2 hours to fix it.
There is a TSB around for it...but not sure about the 03....Since you are in FB, I would call Jerry Fisher at Grand Prairie Ford.
You will have to take it in for a drive but its worth your time to check it out.
BTW do you hear it in speeds over 50 too? I heard mine all the time after 45 mph. It was constant and just got louder the faster I went.
Old Jan 15, 2008 | 01:27 AM
becerraale's Avatar
BTW do you hear it in speeds over 50 too? I heard mine all the time after 45 mph. It was constant and just got louder the faster I went.[/QUOTE]
no its just 43 to 45 mph after that sudenly the drone is gone ?
Old Jan 15, 2008 | 01:30 AM
how I can contact you friend? does he will charge just for check out?[/QUOTE]
send me an email via the site you don't have enough posts to PM yet.
Old Jan 15, 2008 | 01:43 AM
becerraale's Avatar
[/QUOTE]
ok
