Introduction Forum Introduce yourself to the Community here! If you have a technical question, try posting it in the appropriate forum.
New Member jimbo74
Old May 15, 2018 | 07:46 AM
jimbo74's Avatar
5 Year Member
Going to try and post up my own tuner thread, but all the responses I have seen over there seem pretty old.
that 14 qts of mercon v is for tranny pan drop drain and fill AND the torque converter drain and fill by removing it's drainplug? or am I looking at more fluid?
Old May 15, 2018 | 09:47 AM
Just a pan drop only requires 5 quarts.
Old May 15, 2018 | 08:24 PM
jimbo74's Avatar
5 Year Member
Any particular forum favorite for brand of oil to use? I wont skimp on fluids.
amsoil, redline? Other?
Old May 16, 2018 | 11:17 PM
I'm partial to Amsoil in the engine, trans, and diffs if cost is not an issue. Use Motorcraft XL-3 limited slip additive in the rear. Use Motorcraft XL-12 in the transfer case.
Old May 17, 2018 | 08:02 AM
jimbo74's Avatar
5 Year Member
4 oz or 8 oz of friction modifier for the rear? (I have seen both)
Old May 18, 2018 | 07:38 AM
jimbo74's Avatar
5 Year Member
trying to pick up fluids this weekend
Old May 18, 2018 | 10:15 AM
4 oz, if it chatters, put 4 more oz in.
Old May 18, 2018 | 10:30 AM
jimbo74's Avatar
5 Year Member
is it supposed to have 4 oz or 8 oz?
Old May 20, 2018 | 01:40 AM
jimbo74's Avatar
5 Year Member
went shopping today, got some stuff, still need to get more though
got 2 qts of ford xl12
2 bottles of 4oz lubegard friction modifier
6 qts of 5w-20 amsoil signature oil
1 qt of Bosch brake fluid (Dot 3,4,5.1)
2 qts 75w-90 amsoil severe gear
3 qts 75w-140 severe gear
picked up a printed haynes manual today, it says I am supposed to use mercon for the power steering fluid?
as far as the Mercon V for the tranny/tc ---- amsoil doesn't have a mercon 5 specific product ---- is
Signature series Multi-Vehicle Synthetic Automatic Transmission Fluid
https://www.amsoil.com/shop/by-produ...?code=atfqt-ea
ford also has quite a few different coolant formulations, my haynes manual says either Motorcraft Premium Engine Coolant (green in color) or Motorcraft Premium Gold Engine Coolant (yellow in color) in a 50/50 mix with distilled water --- Amsoil does also make some coolant, should I go with that? or is the OE fine?
https://www.amsoil.com/shop/by-produ...ode=antpc1g-ea
Old May 20, 2018 | 09:29 AM
Roadie's Avatar
Use coolant the same color as what is in the cooling system now. Mercon is available at the parts stores.
Old May 20, 2018 | 10:01 AM
jimbo74's Avatar
5 Year Member
The coolant in it is the color of coffee, as is the brake fluid, hence, why I am changing it.
I know I can get factory Mercon @ the parts store, even Walmart has it.
My question was about the Amsoil ATF -- the Amsoil ATF says it covers Mercon 5 and Mercon. Should I be using Mercon for the power steering? or change it out to the X12 like what I will be using in the transfer case?
What about the Amsoil coolant?
I did pick up an ATP transmission filter for the pan drop, and will also be getting a fuel filter. I have also ordered a Spectre chrome rear diff cover with new bolts.
Also picked up some Wagner front E coated rotors and some PosiQuiet pads
Old May 20, 2018 | 12:44 PM
Roadie's Avatar
You shouldn't mix the new long life coolant with the older type that needs changing every couple of years. The older type is green and probably what came in your truck.
I seem to remember reading that you shouldn't use trans fluid that is "compatible" with Mercon or Mercon V.
I would also buy a gasket for the rear diff cover. Using the silocone crap is a great way to get a leak whick will require you to dump your expensive rear lube and try again.
Old May 21, 2018 | 09:46 AM
The Amsoil ATF works well in the tranny and power steering. You can use any Ford spec coolant as long as you do a thorough flush. Just do NOT use GM Dexcool
Old May 25, 2018 | 07:15 AM
jimbo74's Avatar
5 Year Member
don't worry, I will not use Chevy coolant
My local parts store has OEM coolant, in like 5 colors! that's why I originally was puzzled about it.
I will be picking up the Amsoil ATF sometime this weekend
I figure @ 174k miles, and an unknown history, I should change the fluids
Also going to do rear pads, rotors, and shoes
I do need to figure out how to tell what my front gear ratio is, I think I figured out the rear, but notsure onn the open front
Old May 26, 2018 | 12:05 AM
It is the same as the rear, otherwise if you put it in 4wd it would lock up.
