Speedometer cover
Old Oct 7, 2002 | 07:30 PM
RANCH4x4ES's Avatar
Speedometer cover
I somehow aquired a large scratch on the clear plastic piece that covers the speedometer and the other guages (gas, oil, etc). Does anyone know how much a new plastic cover costs and how hard it is to replace the old one myself? Am I going to have to take the whole dash apart to get to it?
Thanks in advance.
Old Oct 7, 2002 | 09:59 PM
grayvader's Avatar
What a coincidence -- I was replacing my gauge faces and used a glass cleaner on the clear piece -- really messed it up and pissed me off. Anyway, I got a new one for < $20. The hardest part about replacing it will be getting the headlight switch off -- there's a bolt behind it that holds the dash surround on there. Otherwise, it's a cinch. Make sure you ahve a torx screwdriver set...
Old Oct 10, 2002 | 11:29 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Thumbs up
I have had my dash apart 10 times or more, and I've never needed a torx screwdriver?? Once you get it apart, try polishing the scratch out using compound and cleaner wax, I've used it before on mine with much success. I also fixed mine after a vinyl cleaner fogged it up, made it look brand new again. Good luck!,,,,98
Old Oct 10, 2002 | 11:07 PM
RANCH4x4ES's Avatar
Thanks guys.
I went to my dealer today and luckily he had one for my truck in stock. With tax it amounted to $27. I took the dash apart and put it in.
Old Oct 20, 2002 | 04:43 AM
SVT2B's Avatar
Torx ? On the back of the switch on the left side , there is a little lever type button , push it and the left side will pull out first , then it pops right out .No torx needed
