hot/cold dial
Old Sep 24, 2002 | 02:44 PM
sturg's Avatar
hot/cold dial
I have a 99 F-150 XLT and the hot/cold dial stopped working. If I pull the **** off, the **** is keyed and fits onto a white plastic shaft. The shaft strips instead of turning and I can't adjust the temperature. I can't seen to even adjust it with my fingers of with a pair of needle-nose pliers. Anybody else run into this?
Thanks,
Jeff
Old Sep 24, 2002 | 02:59 PM
Showya's Avatar
Sounds as if you need a new switch Sturg.
SImple to change, but stay away from the dealer if possible, they want too much $$$.
Showya
(I might even have a few of these around the shop here somewhere)
Old Sep 25, 2002 | 06:42 AM
sturg's Avatar
Showya -
That would be nice. I thought I might have to replace the entire unit. I'll take the dash panel off and take a closer look. Let me know if you have something you think might work. I always try to avoid the dealer if I can.
You can e-mail me offline at: jeff.sturgess@amedd.army.mil
Thanks,
Jeff
