5 speed shifter knob removal?
Old Sep 9, 2001 | 12:47 AM
mootie's Avatar
5 speed shifter **** removal?
Anyone know how to remove the rubbery shifter **** from my 5-speed 1998 F150? I pried up the shift pattern disc expecting to see a nut, but was instead greeted with a black plastic disc that resisted all attempts to turn it or pull it straight up. Is the shifter shaft even threaded. It stumped me for today!
Thanks in advance;
mootie
Old Sep 9, 2001 | 02:19 AM
bambino's Avatar
Just pull straight up, there is no thread on it. Helpful to wiggle it just a bit, it take some grunt, but it'll pop off. Just watch you don't smoke yourself in the forehead!
Old Sep 9, 2001 | 02:12 PM
koehnje's Avatar
It does just lift straight up. I am looking for a replacement **** for a '97. Every time I shift I have to be carefull because mine comes off so easy. I have been to a couple of part stores but with every one I find the diameter of the hole is too small. I havn't tried going through the dealership yet mainly because of what they charge for that kind of thing.
Old Sep 9, 2001 | 02:19 PM
lariat4by4's Avatar
get a **** from the dealer, the're like 10 or 12 dollars i think, and beat it on with a rubber hammer.
TubaMan's Avatar
when you pull your shifter **** off, is it threaded or is it a straight piece of metal?
Old Sep 9, 2001 | 02:26 PM
lariat4by4's Avatar
its splines that cut into the **** the first time you beat it on
