Right rear power window
Old Sep 16, 2010 | 09:14 PM
NVCrewzer4x4's Avatar
I checked the postings and couldn't find anything on this so if it was already covered, my apoligies. Last night I rolled up my right rear window and when it closed there was a shattering noise and the window wouldn't roll up or down by the controls. The window goes up and down freely. I pulled the panel off, checked it out and found that there maybe something wrong with the motor. It seems to work but it is not working the cable that is used to raise and lower the window. Any ideas what is wrong? Is it something that I can repair myself or do I have to take it to the dealer? Any help would be appreciated. Thank you.
Old Oct 31, 2010 | 02:28 PM
termin8r's Avatar
im on the same boat! i took the motor out and the cables that lift the window were tangled and torn so i took the out and will be heading to the stealership for them!
Old Nov 1, 2010 | 11:12 AM
I took the door panel off and after looking at it I decided that I wasn't about to hack into it. I could determine that the cable part had broke. I took it to the dealership and they said that they have seen it happen a few times. They replaced everything and I saved on labor costs because I already had the panel off.
