06 supercrew rear door panel removal?
Old Sep 9, 2007 | 10:50 AM
spooneylove's Avatar
Don't want to break anything...screws at bottom are obvious and behind door latch...what now?
Old Sep 9, 2007 | 10:54 AM
labman1014's Avatar
must remove the top pillar to the back side of the window. if that made any sense. it is the plastic piece that goes up and down on the side of the window that is closest to the rear of the truck. it just pops out, i think 2 clips hold it on and then lift up on the handle and the panel should come right off......
Old Sep 9, 2007 | 10:59 AM
Old Sep 9, 2007 | 01:07 PM
Meatwagon's Avatar
1. Remove the rear window garnish moulding (as Labman mentioned)
2. Remove the window control switch panel & 1 bolt behind (10mm)
3. Remove the rear door handle cover plate & 2 bolts behind (8mm)
4. Remove door handle & guide through the opening in the trim panel
5. Remove the three trim bolts (6 mm) - on at top (beind window garnish in step 1) and two at bottom
6. Lift upward to remove the rear door trim panel.
