popout ashtry stuck in
Old Aug 16, 2007 | 05:13 PM
south_ms_sprcru's Avatar
Ok so i went to push in my ashtray to pop it open and i heard something click and the ashtray just pushed in, like the spring action is gone now and I cant get the ashtray out. how do i remove it and has anyone else had something like this happen to their ashtray?
Old Aug 16, 2007 | 06:25 PM
KDracing's Avatar
yes, i have a 2000 150 same issue, pull out the ashtray so it is flush with dash, then push it back in and pull it all the way out again. do not attempt to completely remove ashtray draw (i learned the hard way) look down inside the dash for a wide piece of slightly bent spring steel, pull that out because it is your return for the ashtray draw. if you look on the backside of the tray you will be able to see where it was platic molded into the draw. you need to reattach it in the same spot exactly horozontal (level) for it to work correctly, i used some gorrilla glue to put i back on. it has been working fine for about four months now.
if you would like me to post pics (walkthrough) let me know
Old Aug 16, 2007 | 07:17 PM
yeah i got it figured out...i removed the ashtray from the dash and found the metal spring below where the ashtray would normally be... i drilled out the two plastic posts that used to attach the metal piece to the ashtray and used two small screws to reattaach it...works like a charm now... thanks for the help
Old Sep 15, 2007 | 12:43 AM
Rabid92's Avatar
this just happned to me on my 2000 this week. ill use 3m double sided adhesive
Old Sep 17, 2007 | 04:11 PM
Les22's Avatar
Mine is so full of change that it doesnt open
(ok stupid post, let the flaming begin)
Old Sep 18, 2007 | 03:06 PM
85gt03m1's Avatar
Help
If it is not too much trouble please post pics. The Cup holder in the dash has quit comming out and the sunglass holder clip has broken off the overhead console. What glue can be used to repair this plastic that is now failing after 7 years in the Texas sun.
Thanks in Advance!
Old Sep 18, 2007 | 03:09 PM
MGDfan's Avatar
Yer trucks care about you - they're trying to tell you to quit !
Old Sep 18, 2007 | 03:13 PM
chumFX4's Avatar
Thanks in Advance!
5 Minute Epoxy will bond almost any plastic permanently.
Old Oct 4, 2007 | 07:55 PM
nozzle28's Avatar
I'm a Newbi!
Hey guys, This is my first post to this site. I have been using it as a reference for about a year and decided to finally register and contribute!
I am having the same problem with my 2001 F150 Supercrew. I just bought it and the ashtray wont spring out. I could use a pic of the spring clip in its proper location if anyone has one to email I would appreciate it.
Old Oct 4, 2007 | 07:56 PM
nozzle28's Avatar
My Mistake, It's a cupholder not an ashtray!
Old Oct 7, 2007 | 01:36 PM
MiamiDave's Avatar
Me too....
Old Oct 7, 2007 | 04:59 PM
nozzle28's Avatar
Hey, I fixed mine yesterday with a 2" hoseclamp, small bolt and nut! I couldnt find the clip that came off so I made one. It works great! I'll post a pic as soon as I can
Old Oct 16, 2007 | 05:59 AM
MiamiDave's Avatar
Pics? More details?
Old Oct 16, 2007 | 09:38 AM
nozzle28's Avatar
Pics of in-dash cupholder
[IMG]www.f150online.com/galleries/thumbs/10572-14918-203598-thumb.jpg[/IMG],[IMG]www.f150online.com/galleries/thumbs/10572-14918-203601-thumb.jpg[/IMG] Here are the pics from my cupholder fix. just be sure to file down any rough edges. Other members have said they used Gorilla glue or 3M double-sided tape instead of bolting. Have fun. I hope this helped!https://www.f150online.com/galleries...cfm?gnum=10572. I cant seem to get the pics to show up in the message but you can follow the link to my photo album.
