Power mirrors work odd
my power mirrors seem to work when they want to. the left will move left but not right, down but not up. my right mirror will move right but not left, and down but no up. should i start with the switch in the door or at the motor in the mirrors???
thanks josh
1999 5.4 auto 4x4 ext cab
thanks josh
I have bumped mine and made the teeth skip that move the mirror. The motor only has so much movement, when the motor isn't correct to the mirror it will max out before the mirror does. I pushed on it and they skiped back to where it would work right, probably not the best way to fix it but it worked.
I had a similar problem with my mirrors. I was advised to get some electrical cleaner ($5 at any auto parts store), pop out the switch and clean it thoroughly. It took about 15-20 minutes and my mirrors have worked fine since.
