dashboard lights and so forth
i have an 06 fx4 screw and it has the green lights on the dashboard and instrument panel. i have 3 other electronic items in my car where the lights are blue. how do i switch from the stock green lights to blue? thanks
It can be done but there is a lot of work involved if you want to change every interior light to blue. I am currently in the process of chaning mine. For the intrument cluster you have to take the whole thing apart and remove the green backing from the overlay. Once that is done you have to figure out what you want to do for lights.
My first atttempt was to put the little blue covers over the lights but that did not turn out as I had hoped. So now I am in the process of doing an led retrofit. I will actualy be soldering in 40+ leds into the cluster. Which should give me the out put that I am looking for.As for all of the other lights in the switch panels and stuff those must also be changed to blue LEDS because they are currently lit up by green Leds.
I have the Leds on order and once I get them in I will do a full write up and let everyone one how it went.
Originally Posted by 1stking
How do you disassemble the dash? I would like to have my dash and surround painted.I have an 07 f150.
