Gear Indicator Wrong
Old Sep 23, 2006 | 11:47 PM
Texas_Scout99's Avatar
Hi all, just a quick question for anyone who can help. The gear indicator on the dash is a little off kilter, so none of the positions are matching up with the actual gear the truck is in (for example, 1 is really Drive, Reverse is really Park, etc.). I imagine all this will take is some time underneath the dash fiddling with the cable. How hard a fix is this, and can anyone provide instructions? Thanks in advance.
Old Sep 24, 2006 | 07:12 PM
LARIAT1's Avatar
From: INDIANA,.....USA " Where more than Corn grows in Indiana"!!!
Question??? Is this on what year F150?? If 98'' Its like my 97'' the gear indicater is out of place , it clips into the bottom of the gauges. You need to remove the trim around the gauges & headlight switch also. Your clip may have broken. Thats what hold it place at the bottom. You need to get a haynes manual to show how & what to remove. Its really not hard to do, just be careful!!!
Lariat#1
Old Sep 24, 2006 | 09:33 PM
Thanks for the reply. The white retaining clip at the bottom of the steering column had broken, so all it required was a minor adjustment. Problem solved.
