Removing Front Door Panel 2006 SCREW
Old Jun 23, 2006 | 05:11 PM
jjnunn's Avatar
I need to remove the front door panel on my 2006 SCREW F150 and can't figure it out. Please help. Any pics, instructions appreciated.
Old Jun 23, 2006 | 05:51 PM
sbull's Avatar
Take the screw out from behind the handle, two on the bottom of the panel; disconnect the locks and windows pull the speaker grill off take the 4 screws out, take the speaker out and disconnect it then lift the entire panel up. Should come off. There are 4 white screw bases where the speaker mounts, you will have to pull the panel away from those when you pull up on it.
Old Jun 23, 2006 | 06:49 PM
faawrenchbndr's Avatar
pm me, I can send you a pdf file from my factory service manual
Old Jun 24, 2006 | 08:42 AM
Mikiedoo's Avatar
I would sure like to get a print out from the schematic. Can you email it to me? I am getting ready to have to venture the same path as the thread starter and will need this help.
My email is ... hmartin9@carolina.rr.com
Thank you for the help (very much)
Mike Martin
Old Feb 25, 2007 | 06:29 AM
ski's Avatar
ski
Registered User
Coul u send me a copy of this. I need to replace my driver side mirror, and could use a how too in removing the panels. Thanks.
Old Feb 26, 2007 | 07:14 PM
jgonza5's Avatar
The following link has the instructions/pics on how to.
http://www.jimmijammer.com/Ford%20F1...20tutorial.htm
Old Feb 26, 2007 | 09:02 PM
referee54's Avatar
That was a well-organized, well thought-out job with the pics and the work involved.
Tim C.
