Sagging driver seat problem?
Old Apr 27, 2006 | 01:31 PM
jeffk185's Avatar
Has anyone else had the problem of the springs wearing out at the seat edge near the driver door? I bought the truck used at about 80k miles, and noticed a slight amount of sag. It's getting worse every month, and now I can feel the unevenness of the seat when I drive.
The edge gets a lot of compression when the driver slides out, and the springs take a beating. Maybe the previous driver was over-weight? I just wanted to see if other people have had this problem and how they fixed it.
Old Apr 27, 2006 | 07:10 PM
BLUE20004X4's Avatar
I'm a heavy fella and bieng so it just reminds me of this through my seat. Unless your a starved boy, it's a problem forever. I will refoam it later prolly.
Old May 3, 2006 | 11:53 PM
blaine96's Avatar
I just priced a new foam insert for my seat, and they run about $100. That seems pricey for a piece of foam. Is this about right, or does anyone know where to get them cheaper?
Old May 9, 2006 | 01:53 PM
keyscrew's Avatar
I bought an 01 with 78,000 miles on it and mine has same problem. Was going to take it to a shop and have re-done. Mine is leather and afraid the leather will start cracking where it sags if not taken care of. Plus there is no support.
Old May 9, 2006 | 11:44 PM
Actually as stupid as it sounds, those elastic snug fit seat covers protect the leather almost completely from the cracking. It really keeps them nice.
Old May 30, 2006 | 03:00 PM
rkjerue's Avatar
The same thing keeps happened to my truck. I had it fixed at an upholstery shop 2 times and the foam keeps sinking down on the left side of the seat. I am beginning to think it is a design flaw in the OEM seats. The only way to fix it is to put in a new cushion and don't slid in and out on that side of the seat but lift yourself in and out carefully.
Another option I am considering is aftermarket seats, I like these what do you guys think?
[Bestop - RoadRider Pro Truck Seats, leather]
http://www.bestop.com/index.php?s=55
Old Oct 1, 2006 | 09:59 PM
sdilecce's Avatar
I've just repaired the bench on my 96 F150. I bought it used, and when I sat in the drivers side I sank right down, but the passengerside and the center were fine. I took a peep underneath and sow some loose wires so I pulled the seat out of the truck.
The problem was not with the foam. The foam is supported underneath by wires attached to a metal rod which is intern supported by springs. It is a lot like a couch actually. On my seat the wires running accross to suppor the foam were broken on the drivers side, and the metal rod was broken as well. I took a piece of 1/8" rod cut it to length and ran it through the springs, and used bailing wire to attach it to the two pieces of broken rod. I then put a pece of bristle board on the foam (To keep the wires from cutting into the foam. Not really nessissary). I then used the bailing wire to make up new support wires to replace all the broken ones. Actually I ran a couple of extra ones just in case.
It worked great. I now sit much higher and the seat is way m ore comfortalbe. It has some spring to it like its supposed to.
