Gauge Pod HELP!
Old Jan 27, 2006 | 03:11 PM
SuperLB51's Avatar
Gauge Pod HELP!
Ok I have an 03 Lightning...I need a triple guage pod thats in the factory light grey and requires no cutting or any fab work done to it....is there one out there? From where? Ive searched forever and only founf ones that need painted, or the are painted but need to be cut because they chenged the design of the apillars from 2002.5-2004 from the earlier models...so anyone know?? Thanks!
Old Feb 12, 2006 | 11:00 AM
Scott 7065's Avatar
Gauge pod
check www.egauges.com they have the best selection of pods that I've found. I've done this install on two trucks now and have found that you will always have to do minor trimming to get a perfect fit. A dremel tool makes this easy. As for pre painted, they have some but not likely yours. However, they do sell the matching paint and it is easy to do yourself. I had my first gauge pod spray painted and the second one professionally dyed to match the interior which is the better way to go. It's a bit expensive though.
Scott
