Expedition seats in an f150??? Help!!!!
Old May 2, 2001 | 11:08 AM
LikeLinus's Avatar
Post Expedition seats in an f150??? Help!!!!
I've got a '98 F150 with the gray 60/40 seats up front. I found a place locally that has a '98 expedition w/ gray leather seats for only $350. They are supposidly in good condition (have yet to see them) and for that price it i'd be worth it. My question is, will these drop in place of the 60/40? The ford place i called around here didn;t know off hand..so i figured i'd ask you people! The only thing that is missing is the center console, but i can get one of those i'm pretty sure.
Old May 2, 2001 | 05:21 PM
ponysix8's Avatar
Post
I've thought about this too since my mom got a 2000 eddie bauer exp. I want gray leather seats from one of those (seat warmers). It's either that or get the 40/60 split leather bound.
If the seats don't fit on the original railing on the floor then it would be easier to take what you need f/ a wrecked expedition.
Old May 2, 2001 | 05:24 PM
LikeLinus's Avatar
Post
I think it would fit, but i wanted to be sure first. I can order an expedition center console for 120 shipped and the seats for 350, so that'd be pretty sweet setup for only 475 or so.
Anyone know?
Old May 2, 2001 | 05:38 PM
troy67's Avatar
Talking
I pulled my 6-way power adjust seats out of a 1985 Mercury Topaz. Beside the power adjust they have power lumbar and they are covered in Grey corderoy cloth. The only thing I needed to do is drill for the inside bolts. And, a heavy piece of steel under them cause the floor pan is so thin along the back of the cab.
97 std. long bed
cat back
2-4 Ground Force drop
w/power lumbar
Pretty plain mono-chrome white. http://troy.f150online.net
Old May 8, 2001 | 04:37 PM
F-150 MAN's Avatar
Post
hey linus...i was going to do the same with the bucket seats and the console...where can you get the console??? ford dealership? any after market places with good prices?
thanks
-The MAN
Old May 8, 2001 | 07:13 PM
BlueFlareside's Avatar
Cool
For the Expy console and seats try www.lwm.cc I got my Expy console from them. Give them a call and ask for Darin.
'98 F-150 XLT SuperCab Flareside, Auto, 4.6L, 4X2, 3.55 LS, 6-CD changer, Moonlight Blue with tan interior, Captains Chairs
Mods:Window tint, Extang Classic Platinum Tonno, Lund Interceptor bug deflector, Wizard Superwhite Bulbs, Pendaliner bedliner, Expedition center console, Airaid FIPK System
My F-150 Page
Expedition Console How-to
[This message has been edited by BlueFlareside (edited 05-10-2001).]
Old May 9, 2001 | 09:46 AM
LikeLinus's Avatar
Post
I was getting the center console from LWM. I wasn't getting the seats from LWM though. They were wanting 600 for the center console w/ cloth seats. Locally i can get leather 98 expedition seats for 350$ and the console costing around $115.
Old May 10, 2001 | 05:30 PM
LWM_Ent's Avatar
Thumbs up
It is relatively easy to put buckets where a 60/40 was. The bucket that goes in place of a "40" will bolt right in. The other side will bolt in on the outside. You must do something about the inner bolts. On most trucks, there are dimples in the floor or actual bolts under the carpet where you need them. If you have dimples, you probably have untapped nuts welded underneath the dimple. If this is so, drill out the sheet metal only (not through the untapped nut). Then you tap the nut out to whatever you like (such as 1/2"). The tap will tell you what size bit to use. Then just bolt the seats in. You can find several good places on this board for console installation. I would try blueflareside for that. I hope this helps. Darrin @ LWM
Old May 14, 2001 | 08:20 AM
TampaSVT's Avatar
Posting Rights Suspended
From: I drive way too fast to worry about cholesterol.
Post
Be sure to get the riser brackets for the seat. The 60 will not fit due to the hump. The part # is below.
DONE!!!!
With the brackets bolted down and the shell off. There are holes in the floor for the brackets. Anyone notice the wires sticking out of the top... Not a bad time to run some wiring for later...
Shell is bolted back on. Lined up perfectly.
The console did not fit flush to the floor. Since it was bracketed on firmly, there was no moving it. Solution, bring the carpet up to meet it. Got under the carpet and filled with some padding. Matches perfectly now.
Interior back together. Upholstery cleaned and Scotchguarded. Ready for the next project...
Part #'s required:
F65Z-1561709-CAJ SUPPORT ASSY. $85.65
YL3Z-1563100-BB SPG ASSY. $51.92
YL3Z-15603A86-BAA HANDLE ASSY. $18.75
Upholstery Shop $200.00
Expedition Console $150.00
Total cost of the conversion = $500.00
Rich
1999.5 SVT Lightning - Red. 100HP Shot NOS, NGK TR6 Plugs, BellTech 3/4 drop, BellTech Nitroactive shocks, Ford MotorSport Chrome Lightning wheels, Super Chip(TRAC). K&N Filter. Viper Alarm w/remote start, Sir Michael's roll pan, smooth corners and steps w/billet inserts, clear corner lenses, Cervinis Ram Air hood, ARE Cover w/ wing, Momo billet pedals, cd changer, cover, Phantom boost and nitrous gauges, MTX Thunderform w/ 2 10" MTX Thunder 4000 subs. 5-channel 500w. Clarion amp.(APA5241), (4)Polk Audio 3-way, 130w. DX 7's, Color-matched Muth signal mirrors, Soundproofed cab, BedRug, Trenz billet grills, Piaa 9007 Super Whites, Bucket Seat Conversion, etc. Build #2755
TampaSVT@Tampabay.rr.com
http://home.tampabay.rr.com/tampasvt/
2001 Lexus IS-300
2001 EB Expedition
Old Jul 12, 2013 | 02:33 AM
ebraunbe's Avatar
Hi guys i have a 2003 f-150 with a one piece bench seat would i be able to put in some expedition seats.
Old Sep 6, 2013 | 12:55 AM
Jet Black's Avatar
K. Another, DOUH! seat install question! My brother has a 2004 XLS he jusyt bought. The dude who owned if before put in caddy seats! And wired in the seat switches in a make shift center console. my questions are;
1- I found a set of the original seats (the one with the seat belts mounted to the seats. The driver's side is pwoers but the pax side isn't. Is it possible to switch out the seat motors from a Ford explorer and mount them to the passenger seat rails?
2- The fuse box plastic cover is missing, and the plastic trim that goes around the lower right hand door sill, and that the fuse box cover attaches too is missing. Is there any place that sells the replacement plastic parts for this??
3- Finally! Window switches. The previous owner operated the windows with two way momentary on switches mounted in the crappy center console. I found a set of door swtiches that will mount on the doors slicker then a snake snot. Does anybody have a wiring diagram for the window switches, AND a wiring diagram for the power seats??
Oh and an original type center console??
Any suggestions appreciate folks!
Thanks for your time!
Old Sep 7, 2013 | 11:48 PM
01 gt f150's Avatar
Expedition seats and console will fit. All you need is a couple of taps to thread the slugs in the floor. The power seat just needs a ground and 20 amp fused power. real easy swap. I did mine a while back and had no issues at all
Old Oct 1, 2013 | 12:09 AM
Jet Black's Avatar
Crash - No arm rests. And I need thge wide console, gray in colour. I know thety can be painted, but I can't find Mar-Hyde dash dye anywhere , here in canada!! Where are you located??
Old Oct 5, 2013 | 12:31 AM
01 gt f150's Avatar
Late model restoration has the special primers and paint in the lightning section
