Dome LIght Intermittantly comes on
Old Feb 1, 2001 | 04:08 PM
tnme2k's Avatar
Question Dome LIght Intermittantly comes on
My '98 F-150 Standard cab sometimes decides a door is ajar, and the dome light along with the intsrument panel warning light comes on. I see no switches on the doors, so how is the interior lighting activated when a door is opened?
Old Feb 1, 2001 | 08:18 PM
Dustoff's Avatar
Post
There is a switch inside that is not visible. Sometimes this switch sticks and causes problems such as you described. This problem has been talked about before..I think others have sprayed WD-40 or something like that into the opening to free up the switch. Ford Rangers also have this problem.
Try a search and see if you can find those threads.
This might help...
https://www.f150online.com/f150board...ML/000352.html
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with super engine cooling/auxiliary transmission cooling HD package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, FORD black tubular cab steps, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil, build 7/2000
[This message has been edited by Dustoff (edited 02-01-2001).]
Old Feb 18, 2001 | 03:02 PM
moose-man's Avatar
Cool
yep yep!
just spray those door mechs with some wd40 give them a good shot and boom problem solved!
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
Old Feb 19, 2001 | 07:21 AM
tnme2k's Avatar
Thumbs up
Thanks for the help, all! It worked perfectly. WD-40 RULZ!
<font face="Verdana, Arial" size="2">Originally posted by moose-man:
yep yep!
</font>
