dash noise
Old Aug 3, 2000 | 05:35 PM
jmsmbry's Avatar
Post dash noise
I have creaking in the plastic components that make up the dash. This seemes to be more noticable on the drivers side and I cannot seem to pin point where it is coming from. I am guessing the various plastic parts expand and contract depending on the temperature thus creating this annoying sound. Anybody have the same trouble? Any ideas how to eliminate the noise?
Old Aug 4, 2000 | 01:02 PM
dakota's Avatar
Post
I have some of the same problems on the passenger side. when I press on the dash it seems to go away. waiting for first service to have it looked at
2001 Supercrew, XLT 4x4,5.4l,tow,captains chairs,
Island Blue & Silver Frost.6 disc changer,keyless entry,bug shield,vent visors,expy console,duraliner bed liner,extang tonneau cover, more to come
Old Aug 10, 2000 | 04:25 AM
GRIDE's Avatar
Angry
I have the same creak on the driver side!!! It seems to be right under the dash near the pocket storage compartment. It gets REALLY bad when it is cold late at night. I have tried to fix it but can't. I am going to take it to the dealer, but it does not do it in the day time. It is really annoying. If you fix it, let me know!!!
1999 Blk F150 Sport 2WD 5.4 Drk Graphite Captain's Chairs, fully Loaded.
Flowmaster cat back 3 inch 70 series muffler w/ 5 inch case, K&N GEN II intake, Superchip, 4:10 Gears.
6.5 inch CAMBURG lift w/35/12.5/16.5 BF muds on Weld wheels.
Dual Billet grills, full tint.
AUDIO= Alpine LCD monitor Head unit, Alpine DDrive Separates all around, 2 JL10 W0 subs in fully custom fiberglass enclosure under reaer seat. Powered by Fosgate POWER series amps. SO CAL RIDE...
Old Aug 18, 2000 | 04:47 PM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Exclamation
I have a similar noise but when push on
the center of the dash,it goes away.
do either of you have aftermarket stereos
? I do,and I,m thinking that it may be the
radio mounting getting loose. Gonna get
mine looked at when I can get to the radio dealer. the gave me a lifetime install guarantee and will use it. They also had the dash apart to put in the alarm,could
be that some of the pads that stop sqeaks and rattles may have been left out
during the install.good luck on the sqeaks
98 F-150 4.6 Litre XLT
K/N gen.II fipk
Custom duals w/glasspacks
color matched Snuglid
headlight covers.
doin the monochromatic boogie on the front end.
on the way(headers,air dam,wheels and tires,etc...........................
Old Sep 9, 2000 | 04:48 AM
PhilippineFord's Avatar
Post
My truck just started to develope the "creaking" sound from the driver's side of the dashboard. It all started when I drove my truck through a twisty lane of highway. The hard left to right motions causes some stress to the actual structure of the cab, and probably caused the creaking to begin on my truck. Every since then, even when making light turns, my dash will creak, even though it never used to. A front strut tower reiforcement bar (like the one on my 95' Mustang GT) would help, but I can't find one here in the Philippines.
Old Sep 12, 2000 | 10:32 PM
hondacr250r's Avatar
Unhappy
I have a creaking noise passenger side on my 2000 f150xlt . have not made it to the dealer yet.
Old Sep 15, 2000 | 04:20 PM
dakota's Avatar
Thumbs up
FOLLOW UP Took me crew in for first service, told service manager about the noise in dash they took out airbag, glovebox and I still had the noise. After that they found one dash bracket was loose tightened the bolt. No noise. relieved
2001 Supercrew, XLT 4x4,5.4l,tow,3.55ls, captains chairs
Old Sep 15, 2000 | 09:59 PM
Post
Took my truck to the local dealer on 9-13-00 with a noisey dashboard. Service tech. said they could disassemble the dash install some double sided tape in the trouble spots as well as check for lose parts. I could not part with my f150 for 2 days ,so I went home took that oval section out that is on the 2000 models it just clips in ,be careful they are fragile,and then I just pressed on the dash until I found the noise. next I sprayed armorall until the noise was gone. Took it for a road test, no more creaking dash board for now!
2000 F150 XLT 4.2L 3.55 silver clearcoat metallic styleside,mobil15w30synthetic,k&n filter charger,bedmat
Old Sep 24, 2000 | 09:41 PM
dnale's Avatar
Thumbs down
I hate to bad mouth my ford, but I think that we all are experiencing something we will have to deal with for the life of the trucks. I took mine in before I was out of warranty, and they supposedly found the source. About two hours later I had a new rattle and the old one is back. I pull the fuse box cover and that seems to stop some of the noise. I thought I saw somewhere about putting some tape there. I hope we can get this taken care of cause I am gonna have this truck for a long time. (I need to pay it off!)
'99 F150 SC Lariat 4x4 Deep Wedgewood Blue with Harvest Gold 2-Tone, Medium Prairie Tan Leather (getting seat repaired), all the factory options (minus captain's chairs, 6 disc cd changer, ford tonnuea and push button 4wd) Polar Bear Brush Guard, Ford Factory Steb Bars, Extang Tonnuea Cover, Duracoat Liner with Rubber Mat, Flowmaster 50 series, Superchip, K&N Filter, Airbox Mod and Silencer Removed, 2 Rockford Fosgate 8"'s and a 250 watts RF amp
Old Oct 3, 2000 | 10:54 PM
Post
since my first reply about creeking dashboards Ihave applied one more application of armorall, so far so good!
Old May 10, 2008 | 09:03 PM
MDFX4's Avatar
I found a solution to this
If anyone checks this thread. My plastic rubbing noise was coming from the photocell/Alarm LED next to the drivers grill. Pull the heater windshield grill and unclip the harness from the photocell/alarm LED. I had to stick a piece of electrical tap in the female connector of the harness to make the noise go away.
