Help me clean my headliner before i kill my GF
I like 'Tuff Stuff'. Like they said, don't use the plastic scrubber. Work it in with a terry cloth.
Oh, and scrap the GF. Cheaper than shooting her. No messy court fees & no jail time. Or messy cleanp-up.
depending on you comp deductible you may just want to let your insurance company change it out. I was designated driver one night my friend put a cigarette hole in the headliner paid my fifty bucks got a whole new headliner.
I also found some dryed up bubble gum (or something) on the door window, I scrubbed so hard trying to get it off, I had to quit because I was afraid I would damage the tint. I may just let it wear off over time, cause that crap is on there!!
Try some Peanut Butter on the gum!!! It should soften it up to remove it. Worked great to get the gum out of my kids hair, should work to get it off a window. And as far as the headliner, I would just try using a spray bottle with very hot water and blot, blot, blot with a clean white towel. Good luck, looks like it make take awhile to clean.....
headrest
get a can of cheap carpet cleaner in a spray can, its only 99cents a can at Wal Mart, spray it on and let it dry and brush it off, and btw, get another girlfriend, you should have made her clean it.
Before you laugh at what I'm going to say, you can't use anything abrasive on that headliner. Scrubbing will make it worse. If it was me...now don't laugh at what I'm going to say....I would try like the smaller portable "green machine". You have to dilute that stain down and clean/remove it with a water/soap/cleaner solution to make it disappear. Then vacuum out the liquid with that machine. I really believe that would do the job. The little green machine would get it out, the hardest part would be sucking out the moisture. Try it on a little portion. It has saved my **** on other projects....Good luck! I feel for you man!
