2004 Lariat "Wood" Trim Dash Panel Squeek
With less than 500 miles on my new 04 Screw Lariat, the fake wood dash panel that surrounds the radio/ac has a annoying squeeking noise. I can stop the noise by lightly pressing on the face of the unit. Does anyone have this same problem, and have you found a way to correct the problem?
How do you remove this trim piece?
if when you remove that center i/p panel and it is held by clips, (im assuming they are since i havent removedmine yet to look) spread the clips out so that they will retain better and or add a small piece of foam on each side.
