Sunroof Control
Old Sep 8, 2004 | 12:40 PM
harley9668's Avatar
Sunroof Control
Help! I just bought a 2004 F150 XLT that has a sunroof. When you open the sunroof it is automatic with a one push rocker button (similar to the drivers window) but try to close the sunroof. You mess with the rocker button trying to ensure the sunroof is completely closed. Your never sure until you get water on the inside of the cab or your driving down the highway hearing the wind whistling through the open sunroof. Does anyone have an easy way to shut the sunroof?
Thanks!!
Old Sep 8, 2004 | 01:09 PM
Javelin389's Avatar
Hold the button down long enough to ensure that it is fully closed. When it does close, you will notice that the rear of the panel is slightly higher than the front. It would have been nice to have it automatically close - just like it opens.
Old Sep 8, 2004 | 01:12 PM
harley9668's Avatar
Thanks! I do that but if you hold the button down too long it pops back open. Very frustrating......
Old Sep 8, 2004 | 08:40 PM
DrPaul84's Avatar
its not popping back open, its going up, and closing, when you open the sunroof, it drops down a bit, so that it can slide back, so when you close it, it slides forward, then goes back up to where it started, just hold the button to close untill it stops moving, then you are done, dont touch it anymore....
