interior paint
Old Aug 29, 2004 | 04:10 PM
blown330's Avatar
interior paint
anyone know what paint is good for the interior dash?
i would like it to look like factory, maybe like the dark grey found in the mach 1.
should i use flat paint or semi gloss?
thanks in advance!
Old Aug 31, 2004 | 05:25 PM
RayCee's Avatar
Might want to check out the dealer for interior paint. I painted my pillar pod and the match was perfect.
Old Sep 1, 2004 | 03:12 AM
ahawkers's Avatar
best bet if u wanna make it look sharp is ssand it all down nice and smooth then primer then any type of paint will do if ur doing just the plastic pieces. if ur doing some vinyl parts, then ull need some 30% flex in ur primer, but yeah i painted mine with dodge exterior paint, (intense blue) and it looks sweet.
Old Sep 1, 2004 | 06:13 PM
Buckfu's Avatar
I used Dupli Color's High Performance Wheel Coating paint for several of my dash pieces...sand, prime, 2 coats of paint, and 2 coats of clear and it turned out pretty nice.
Old Sep 9, 2004 | 09:30 PM
blown330's Avatar
thanks for the replies!
do you think i should paint or put leather on the dash? ( a friend came up w/ that one)
i want my truck to be more luxurious ( spell?) on the inside.
Old Sep 9, 2004 | 10:10 PM
TonyPTX's Avatar
For some unknown reason, I have this Ford part number written down as a OEM vinyl paint that you can use to paint plastic interior peices....I don't remember where I got it from, or if it applies to you, but it's something that can't hurt to check out at the parts counter.
M4JZ-19M547-4245-H Ford Medium Graphite Interior Plastic Paint
Tony
Old Sep 14, 2004 | 06:19 AM
blown330's Avatar
thanks for the info!
