Wet carpet on passenger side
Old Jul 24, 2004 | 10:19 PM
tj_03supercrew's Avatar
Unhappy Wet carpet on passenger side
I was vaccuming out the interior of my truck recently and pulled out the factory floor mats to vaccum the carpet. The passenger side carper was wet underneath the mat, the mat was dry. I was surprised as to the amount of water there, it took me several minutes with a shop vac to get most of it up. I tried feeling around underneath the dash but came up with nothing. Unfortunately, it had been damp under the mat for a while and the carpet is somewhat stained now!
Anyone seen this or have any idea what it is?
Thanks in advance!
Old Jul 25, 2004 | 09:45 AM
Quintin's Avatar
When you're running the A/C, is there a puddle of water dripping out from underneath the truck on the passenger's side? If it doesn't smell like coolant, there's a good chance the evaporator drain is plugged up, allowing condensation off the evaporator to leak inside the truck.
Old Jul 25, 2004 | 02:32 PM
There is usually a decent size puddle of water after running the A/C.
Old Jul 25, 2004 | 06:53 PM
TexfordD's Avatar
A/C drain is clooged up. There is an elbow piece that they will stick on to solve the problem. If it,s under warrenty it's covered.
Old Jul 25, 2004 | 09:17 PM
It's under warranty. I'm due for an oil change soon so I'll have them take care of it then. Hopefully I can get the dealer to replace the carpet too, since it is stained from all of this, but we'll have to see.
Thanks for the info guys!
Old Jul 28, 2004 | 09:57 PM
TexfordD's Avatar
TJ ...you still running around with the wet carpet?
Old Jul 29, 2004 | 09:38 PM
yeah...unfortunately I am, but I'm going to the dealer tomorrow if possible.
Old Jul 29, 2004 | 10:23 PM
TexfordD's Avatar
Don't let the dealer loose on that elbow...or you'll just have to bring it back
