How to remove 97 Passenger Door Panel
Old Mar 9, 2004 | 09:02 PM
Darkness's Avatar
Well the title says it all. How?
Old Mar 11, 2004 | 10:01 AM
daywen's Avatar
If you have a Haynes manual, it gives pretty good instructions.
When I get home I will post the directions.
Old Mar 11, 2004 | 10:18 PM
daywen's Avatar
1. Remove window crank/switch plate. Disconnect power plugs.
2. Pry side view mirror trim cover and the door panel retaining clip.
3. Pry off doo pillar cover and upper retaining clip.
4. Pry off door handle cover (Little round plug by door handle) and remove the screw and handle.
5. With wide putty knife or special tool, pry out the plastic retaining clip securing hte front edge of the panel.\
6. Once all clips and screws are disengaged, detach trim panel and detach any electrical connections and remove the panel by pulling up and out.
Hopefully this helps you out!
Old Mar 13, 2004 | 08:10 AM
rdtrk4x4's Avatar
Check this site out, (pictures). Got it from another members post.
On the left side of the home page you'll see the main menu, go down to the Tech / How to.
www.modernengineuity.com
