inner door panel removal of 2000 ford f150
Old Mar 6, 2004 | 10:55 AM
walt8833's Avatar
Question inner door panel removal of 2000 ford f150
I am tryingto removce the inner door panel on the passenger side to replace outer handle and check door lock actuators. OI dont know how to get the panel loose.
Old Mar 6, 2004 | 03:38 PM
Fritzthecat's Avatar
1-Pop off the rear window trim and remove screw.
2-Pop off the plastic cover behind the door handle and remove screw.
3-If electric, pop up the control panel (lift front first) and disconnect plugs.
4-If manual, remove window crank.
5-Lift door panel up and out.
6-Disconnect door light if installed.
Reverse to install
Fritz
