interior colour
Old Apr 28, 2003 | 08:31 PM
mbuechler's Avatar
Registered User
interior colour
I have the beige interior does anyone know what colour the plastic pieces are under the biege or are they biege plastic all the way through. I don't know if my question makes sense but I have seen vehicles were you can rub right through the outside colour!
Old Apr 28, 2003 | 08:46 PM
ROUSHFAN-1's Avatar
Some are solid color...Some are black painted with the biege....Mostly the dash parts are painted the doors kick panels and rear wall parts are solid color....
Old Apr 28, 2003 | 09:42 PM
BigDeal's Avatar
I can tell you for sure that the power switch bezel on my drivers door is black under the paint. How do I know this? Because my left knee has worn the beige paint right off. Guess I'll be ordering some interior paint real soon.
Old Apr 28, 2003 | 09:48 PM
Rockpick's Avatar
Moderator &
I believe the interior color is known as Medium Parchment.
You can buy the paint from www.paintscratch.com . If you plan on using it on the interior, be sure to have them add the 'flex additive'.
In my past experiences with it, it's not an EXACT match but, it's very close.
RP
Old May 8, 2003 | 10:42 AM
98SCREAMER's Avatar
From: Houston, by way of every major city in America.
Thumbs up
Yeah, most of the dash is painted ABS plastic. Aside from the oval piece on the top of the right side dash. The door panels are mostly molded in color, except for the door switch plates. The best cleaner out there I've found, is the Ford all purpose cleaner. You can buy it at the dealer. Some interior cleaners (namely Tuff Stuff) can actually take the paint off the ABS parts.
If you need to respray the interior, SEM has a close matching dye. Ford also carries a matching dye in a spray can. I have seen it in a dealer bodyshop where I worked. It may take a little whining to get the guy to look it up. Kind of like trying to find clips or rubber door bumpers Good luck!,,,,98
www.semproducts.com
