DRL's causing hyper flash
Old Feb 20, 2021 | 06:24 PM
jdflow's Avatar
So I turned on my DRLs using Forscan. I opted to have the fogs and the parking lamps together. But doing so has created a hyperflash with my directionals.
i can easily just change it to fogs only but just seems odd for that to happen. Anyy ideas?
Old Feb 20, 2021 | 08:37 PM
gDMJoe's Avatar
Exclamation
jdflow ...
Vehicle information?
HINT/TIP: Put your vehicle information (year, model, cab, trim, engine, wheelbase, _x4 drive, mileage, modifications, etc., etc.) in your signature -OR- provide it in your posting(s).
» Edit Signature «
Old Feb 20, 2021 | 08:50 PM
The OP has a: 2014 STX 4x4 sport extracab 5.0 with 115k
Old Feb 20, 2021 | 09:05 PM
jdflow's Avatar
i have it in my profile. will edit sig.
2014 5.0 supercab 6.5bed STX 4x4 Sport. 115K stock
Old Feb 20, 2021 | 10:01 PM
jdflow's Avatar
I posted this in the 09-14 forum also but seems more appropriate here.
i turned on my DRL's using forscan. I opted for both the fogs and the parking lamps. Now my directionals hyper flash. Easy enough to changed to just fogs but why did that happen?
I wanted to get aftermarket headlights with DRL's and tap the parking lights. Can't do that with the hyper flash.
2014 STX 5.0
Old Feb 21, 2021 | 04:38 PM
jdflow's Avatar
I solved this. For others that this may happen to, when I turned on the DRL's, i also enabled the bulb out notification all around. Turning this off solved the hyperflash.
