2013 F150 running lights
Hope someone can help, looking for the correct wire colors to splice into in the floor sills o 2013 F150 to run led running/ door open courtesy lights under doors. There are three wires on led running lights 1-ground and 1each positive for running and courtesy. Trying to find out which color wires are correct to splice into.Thanks for any help. Bill
On the passenger side there is a green connector that should have a grey with yellow tracer wire in it. That is what someone spliced my door sill LEDs. I am unsure if it is available on the driver's side. The parking is a yellow with blue tracer I believe at the bcm. My truck has powerscope mirrors so I was able to use that on the driver's side. Link if you find the courtesy lamp on the driver's side.
