HID Radio interference
Old Dec 7, 2014 | 10:56 AM
klhmn's Avatar
I installed some and HID kit from Raptor Retrofit, it works great. Had an issue with a ballet they sent me new one asap.
My issue and I have contacted them and they where no help here, radio interference. They said they don't or haven't had issue. It sucks, I have tried line chokes on various wires, radio antenna anyone else run into radio interference and where you able to correct it?
Old Dec 7, 2014 | 11:59 AM
03f15012's Avatar
I ran into it on my old kit, (screw you PnP, you can go die in a fire) but never got it fixed. I haven't seen if my current retrofit causes interference though, as I barely listen to the radio.
Old Dec 7, 2014 | 12:34 PM
Raptor05121's Avatar
Its the ballasts. They emit RFI. The only way to correct it is to cover the ballast and igniter with braided static chokes. Or use OEM ballasts that already have them. I went from Morimoto ballasts with pure static to OEM Matsu****a and I can pick up radio stations 200 miles a way now (like it used to be).
Denso-Ballast.jpg?t=1302260735
Old Dec 7, 2014 | 01:10 PM
thelariat02's Avatar
This ^ my morimoto where the same way. I went to the Matsus. With an external igniter and have no static.. Upgrade to the new XB ballasts that trs sells. They have an external igniter so should cut down a lot on RFI
Old Dec 16, 2014 | 06:49 PM
klhmn's Avatar
Cool thanks
