Lights Behind Grill
12V 100 watt Xenophot® 2000 hour bulb
• LIGHT OUTPUT (12V) 1 lux @ 900 m
• Lightweight polycarbonate, glass filled nylon composite construction
• WEIGHT (single unit) 880g | 1lb 15oz
Here's the specs on the 35w HID version
LIGHT OUTPUT | 1 lux @ > 1200+ m
• 12V 35 watt HID (internal ballast - plug ‘n play)
• Billet alloy focal rings for customizing beam angle pattern: 9.8° | 11.8°
• WEIGHT (single unit) 1.55 kg | 3lb 6.67oz
I looked them up and saw those same numbers, but how does a "lux" compare to lumens in layman's terms? Lux(es) factor in square meters or feet at a certain distance to measure output, right? Something along those lines. It's like thinking of speed in KPH vs MPH to me
Hmmmm ... wellsir, one coud reasonably expect that you would actually follow the same advice you so blithely dispensed to the OP here:
Originally Posted by KMAC-Attack
Please just look at the threads under the Google link, there are like 10 detailed threads about how you exactly go about doing this. Do some homework
http://www.statelineeco.com/resource...x-vs-watt.html
http://www.greenbusinesslight.com/pa...mens-and-watts
http://www.ledrise.com/shop_content.php?coID=19
BTW - it is 110% NOT like yer mph to kph analogy; those are both a measure of the exact same thing, only the units are different. A more accurate analogy would be velocity versus acceleration....or mass versus pressure ... or ... well, you be git'n da pitcher, aight?
Class dismissed
OP - very sorry fer the hijack, but this here feller needs to go stand in a corner and beat himsef wif a stick, lol.
Cheers
Oye . . . point taken. I didn't understand the links I found; those are better. Only one of them, the least helpful, showed up under my search criteria. However, I provided links already and he didn't even bother to open them. I could say more, but I'm gonna refrain. You never change, do ya?
My KPH and MPH was for thinking purposes, not a direct comparison. Maybe try to understand intent versus literal comparison, I came up with that analogy in 2 seconds.
If yer going for a thinking analogy, it may as well be one that applies
It's all good ... at least you ARE thinking
Hey - how did ye knowed them thar linkeroonies warn't opened... ye gifted?
Cheers
Damn right I ARE thinkin! Or is it that I BE thinkin?
And because he asked a question that would've been answered by the links haha.
I gotta give you credit on the KMAC and Cheese, that was pretty good
https://www.f150online.com/forums/il...installed.html
Thats my thread about puttingmy 32" LED lightbar behind my grill.
