A simpler way to retrofit your headlights
Possibly a simpler way to retrofit your headlights,
Tools needed,
Drill
2 3/4" hole saw
1" dowel rod 6" long
Roll of tape
Flap wheel sanding drum for drills.
Cut your dowel to the desired length 6" will do, longer will work as well.
Find center of dowel and drill a hole a size smaller than your hole saw piloting bit. Mine is a bit off, they make a ring that does as well as a little time would help, I got into a rush.
As straight as possible sink hole saw bit into pilot hole.The dowel is a bit smaller than the bulb socket so rap a few bands of tape around to get it to size.
Insert jig into light and cut away.
Sand in places where necessary as the Fxr projectors are a bit more oval than round.
Shim the housing to get the bowl level in both directions.
Use a 2 1/2" hole saw bit to level/plumb the projector.
By my way of thinking, if the bowl is right, and I match the projector to the bowl then, I should be very close to straight upon installation.
But I will not know for sure until I install them.
I do not have pictures, but once leveled I took a machine screw, dipped the end in paint and lowered it down through the mounting hole to mark where to drill. Start with a small bit 1/8 or so and then move on to the bit size necessary for your screws.
Then attach as listed in the retrofit how to.
I hope this helps, it costs a little more to buy the hole saw bits if you don't have them, however it is faster and much easier to center the hole.
Tools needed,
Drill
2 3/4" hole saw
Roll of tape
I did it with the Dremell at first, but mine is cordless and the battery kept dyeing on me, so I thought there must be a way to do this and center the hole better.
My thought with the level is that if the bucket is aimed correctly, and I match my projector to that I should be pretty damn close to strait. We'll see in a week or so as I ordered the wrong Halos from TRS and have to wait on the exchanged set to arrive.
The other thing I might add is, that I enlarged the mounting holes in the projector housings to allow me to fine tune the rotational alignment of the projector.
Tools needed,
Drill
2 3/4" hole saw
Roll of tape
This image should be turned 90*
Tools needed,
Drill
2 3/4" hole saw
Roll of tape
Here is the how to, the procedure I listed above is not as much about time as it is about centering your hole accurately. It is faster, very slightly cleaner, but it eliminates a lot of the trail/error sand to fit procedure. You still will need to sand a little as the projectors are slightly more oval than round.
I may be selling this set later after completion, as I have an idea in mind for something a little bit wilder.
