LED Replacement Kit?
Old Dec 7, 2012 | 10:13 AM
Rockpick's Avatar
Moderator &
Does anyone know if there is a LED replacement kit for all interior/exterior lights on a 2012 SuperCrew?
I had changed ALL of my bulbs (plate illumination, bed lights, interior (dome/map), and under mirror lights to LEDs. I really liked the look.
Has anyone gone down this path for replacement bulbs yet? Cheap and easy mod that I think I'd like to do again -- if I can get the right bulb numbers.
Thanks folks!
-RP-
Old Dec 7, 2012 | 11:14 AM
fine_style150's Avatar
I dont know of a kit RP but what you can do is find the bulbs seperately, and double check the right ones thru:
https://www.sylvania.com/en-us/appli...s/lrgmain.aspx
When I went about replacing my bulbs I referenced the guide to make sure I wouldnt be going back to the store and finding the right led
Old Dec 7, 2012 | 01:27 PM
Rockpick's Avatar
Moderator &
Good advice, fine. I had previously dealt with superbrightleds.com and had good luck with them.
It's not a tremendous expenditure... so, I may just start experimenting with a few bulb styles/colors (warm white vs. white).
