Headlight questions for FX4...
Old Oct 25, 2012 | 02:59 PM
Kawasaki268F's Avatar
Guys- new headlights will always fog up!
This seems to be a common misunderstanding here. Unless you have visible water droplets forming a puddle in the bottom of your housings, there are nothing wrong with your headlights. They may have been made in China, but they still do full submersion tests on the housings prior to shipment. Due to atmospheric changes, they will fog up anywhere from 1-7 days before they equalize. Sometimes taking the bulb out will help (only hot and dry days) but there are one or two fabric vents over a small 7/16" hole on the back of your headlights that act as one-way gates to allow the moisture to escape.
tl;dr- Fogging is normal. Unless you have water pooling up on the bottom, there is no need to run silicone around the edges.
Haha okay, so don't bother with the silicone then??
Old Oct 25, 2012 | 03:41 PM
Raptor05121's Avatar
Exactly. If a week goes by and/or you have more than a couple ounces of water sitting on the bottom, don't bother. My headlights have a GAPING hole in them from my retrofit. You could stick two fingers inside my headlight. Point being, you never want to fully 100% seal off a housing. You want some vent flow, and stock lights have these.
Old Oct 25, 2012 | 10:19 PM
Just a question, are those Sylvania Ultra's fairly white like HID's? what is the deal with those Sylvania zXE's?
Old Oct 26, 2012 | 10:23 AM
I guess I will try out the Ultra's or the zXE's, both look to be fairly white
Old Oct 26, 2012 | 11:23 AM
benchwarmer4203's Avatar
I've bought several sets of these knock-offs from Ebay with constant fogging issues (well beyond a break-in period) unless RTV was applied. A good quality automotive RTV solved the problem. Applying the RTV doesn't affect the natural venting of the lights through the designed vent locations, so from my experience, it's worth a couple extra bucks.
Old Oct 26, 2012 | 12:07 PM
No halogen will look like HID. Ultras have a decent power output with a relatively short life and zXe's supposedly have more light with even less life span.
Old Oct 26, 2012 | 01:29 PM
thiggins's Avatar
Try the PIAA Xtreme's, I like them. Nice white light.
Old Oct 26, 2012 | 08:02 PM
SSCULLY's Avatar
Guys- new headlights will always fog up!...<snip>....
In 2006, the Ford HD housing I got ( actual Ford ones from Tasca ) did not fog up at all after install.
UPS showed up with them, I took them out of the box, installed them and ever since no fogging.
Old Oct 27, 2012 | 07:45 AM
This depends on climate where manufactured, stored, and installed.....
Old Oct 27, 2012 | 12:19 PM
Those look great...just not sure if I want to spend $70, I may just wait till I can do projectors
Old Oct 27, 2012 | 12:20 PM
Hmm, well what would you recommend over the stock bulbs until I can afford projectors?
Old Oct 28, 2012 | 11:17 AM
That's the very likely chance they were manufactured and packaged in the same climate you are. I've had a set like this as well.
Sylvania Silverstar Ultras or Philips Xtreme Powers
Old Oct 28, 2012 | 12:55 PM
Thanks! I will pick up a set of the Silverstar Ultra's next weekend
Old Oct 28, 2012 | 07:47 PM
SSCULLY's Avatar
That's the very likely chance they were manufactured and packaged in the same climate you are....<snip>...
Not even close.
Mexico ( manufacture ) to Rhode Island ( Tasca ) to Chicago w/ summer time 80%+ humidity.
...<snip>... I've had a set like this as well...<snip>...
So new headlights will not always fog up.
