Fog light reflective chrome?
He guys. I had some flooding in my area and got my truck pretty deep in water. My truck is a 04 lariat and I replaced my fogs bulbs twice. There was glass every where in the housing so I decided to take them apart to get the glass out and buff out the inner and outer fog light cover while I was at it.
Next I wiped the chrome plasic reflective part lightly with a towel and the chrome is just peeling off. I noticed my other light that I haven't touched yet is in really bad shape. What would you guys suggest? Re paint with something, replace, any ideas? Thanks.
The reflective coating is a plastic resin-based coating which is sprayed on really lightly. Just about any amount of wiping will remove it as you can see. If you use your fog lights fairly often, I would replace them. Otherwise, you'll take a huge hit in reflective output from the bulbs alone.
http://www.ebay.com/itm/270997903606...84.m1423.l2649
Im going to search eBay. The round ones won't work I have the rectangle ones. Anybody know of a replacement or after market that will fit in there? Stock ones $80-$90 a piece.
I see you're talking about the reflective chrome to aim your lights...yeah needs to be replaced. I thought you were referring to a lens or covering over the bulb, not the reflective stuff behind it. Look on eBay I found some good ones recently:
Oh hell yeah. Thanks
If you visit any auto parts store, they will most likely sell (probably have to order) chrome paint (in a spray can). It will work well, and cost about $10....been around for a few decades..........
Not nearly the same stuff. And if it did work, it would be almost instantaneous before it started peeling or burning
Sounds better than it works.....
