Retrofit question
Old Sep 3, 2012 | 01:29 AM
MTXThunder9500's Avatar
Retrofit question
Question for those of you who have done the retrofit. How did u get the glue off after you took the lenses off? I got my lenses off the lights but this glue is gonna suck. Also what do you do to regular the lens on?
Old Sep 3, 2012 | 09:15 AM
Raptor05121's Avatar
The question is: stock or aftermarket? My aftermarket lenses used some kind of butyl rubber that was very well still sticky. I just popped them off, did my retro, and then heated them back up and sealed it back together. If it is a OEM PermaSeal unit, I would heat it up and use a flathead screwdriver or hobby knife to get it all off and then buy some new butyl rubber (http://www.theretrofitsource.com/pro...roducts_id=792) to seal it all back up.
Old Sep 3, 2012 | 11:48 AM
Mine are aftermarket that i am using. I did by some of that butyl rubber from them to use to reseal them. Could i just put on on over the old stuff or should i heat it up and take off the other stuff first? I ask that question cause i already started to pick at some of the stuff that was on the light to begin with after i took them apart.
Old Sep 3, 2012 | 06:58 PM
sam1947's Avatar
When I did mine, and a few other re-seals I used a 1/4" wood chisel in the channel. You just have to be careful and take your time, a wood chisel can leave a nasty cut if it slips.
Old Sep 4, 2012 | 01:12 AM
You could've just put the halves back together and heat it back up to reactivate the bonding agent.
Old Dec 25, 2012 | 01:17 PM
ford4life.'s Avatar
When I took mine apart they where a big pain in my ***
