DDM Tuning HID Wiring Colors..HELP ASAP
I have an 07 F-150 XL and was wondering which wires go to which...I was an idiot and didn't mark them before I redid the connection -.-
The green wire actually has a black stripe on it, you just can't see it...the other one is green with a red stripe.
Also, a side question...I am actually soldering these connections and using heat shrink to make sure its a good connection...before I just had these crappy wire connectors...I noticed that when it rains my left HID won't turn on...I can hear the ballast making a noise like it wants to turn on, but I am not sure what the problem is...when it is dry it turns on just fine...anyone have any ideas what the problem could be? (This is part of the reason as to why I am redoing the connections...I also noticed where I put the ground the metal was rusted, so I put it in a new spot...hopefully all this fixes the problem, hopefully it isn't the ballast.)
I got it...not sure what you mean by ballast noise? It isn't making a loud noise, I just said when it is wet and rainy I can hear that the ballast is on, but the bulb won't turn on...anyways hopefully the things I did today will fix the issues
