led tailight bar
Old May 2, 2012 | 12:14 AM
db5's Avatar
db5
led tailight bar
about to pick up a brand new 60'' led taillight bar for 30 bucks!
comes with the regular brake light blinkers and reverse..is that a good deal?
and also does anyone know how hard it is to wire it to the reverse lights?
Old May 2, 2012 | 09:58 AM
SSCULLY's Avatar
Depends on the brand, or a lack of brand ( knock off ). In general I would say yes.
Do you have the 7 pin trailer tow adapter on your truck ?
- If so the reverse circuit is in that trailer tow adapter.
I can only say for sure about the '01 & '06 MY, that 1 A additional load on the truck's reverse lamps is not doable.
The lamps will not burn at full brightness.
Supposition on my part is the contacts in the DTR ( Digital Transmission Range ) Sensor are too small to carry the additional load, it is sized exactly for the 2 x 26W bulbs that the truck has.
Old May 4, 2012 | 11:46 AM
Raptor05121's Avatar
OP, if you have the 7-pin like stated above, you can wire it in there or you can run the wire to your tail lamp and splice in there. If you bought it new for $30, don't expect much in terms of quality. My Plasmaglow was $75 and I think the Recon models cost the same, and they already have varying quality per differing members on this site.
Old May 18, 2012 | 12:42 AM
tony05ford's Avatar
hard wire the back up light into one of the reverese. lights on the back leave enough wire incase you have to remove it again later.
