Rocker Switch Install
Old Oct 14, 2013 | 05:51 AM
timmypstyle's Avatar
The one in the 2nd pic on the headlight switch panel is what I did. Any more I install will be under the heater controls like the 1st pic.
Old Oct 15, 2013 | 12:11 AM
PKRanch's Avatar
I assume you had to drill into the dashboard (besides the switch panel) to make fit? This was my problem/hurdle, when I installed on the headlight switch panel...unless I wanted it right next to the headlight turn switch.
Old Oct 17, 2013 | 07:04 AM
I took that panel off and drilled the hole into it. I try to choose smaller panels that would not be hard to find if I was going to sell the truck but keep the toggle or whatever. In my 04 heritage I put 2 toggles in my fuse box panel.
Old Aug 17, 2014 | 10:00 PM
PKRanch's Avatar
Did you have to drill out the dash to get this rocker to fit ? I drilled out a hole to install a similar if not identical rocker switch and am having clearance issues with the dash. Right now I'm reluctant to touch the dash.
[IMG][/IMG]
Old Aug 18, 2014 | 04:03 AM
Mine fit perfect afterwards. Only difference was the rocker is upside down compared to mine. You will want the led pointing down when lit because it's bright and annoying. I didn't have to touch the dash at all. The panel does take a little roughness to get it back in but not a ton of force.
Old Aug 18, 2014 | 12:03 PM
dbhost's Avatar
I need to get into the truck with a camera and take photo of mine. I used the plate the lighter socket is in, on my XLT the lighter socket is dead center, so the 2 outer positions get a rocker switch, one for the fog lights up front, the other for the reverse accessory lights.
Old Aug 23, 2014 | 12:03 AM
That's the route I would go if I added more toggles for stuff. I think you can fit 2 per side.
Old Aug 23, 2014 | 12:27 PM
Raptor05121's Avatar
Timmy, whats up buddy. Haven't seen you in a while
Old Aug 25, 2014 | 05:44 AM
Lol haven't seen you in awhile. Not much going here. Still have your...what was it..? 01 f150?
Old Aug 25, 2014 | 05:45 AM
Don't want to hijack. Send me a pm bud.
Old Feb 17, 2016 | 12:40 AM
PKRanch's Avatar
Old Feb 19, 2016 | 11:40 AM
PKRanch's Avatar
Old Feb 24, 2016 | 01:17 AM
Geez! How many toggles do you need? I think someone has an addiction lol.
Old Feb 24, 2016 | 01:18 AM
I just did one on my ram today. Installed an extra toggle for later.
Old Feb 24, 2016 | 01:44 AM
