Running 12 volt dc to rear of truck on a 2011
What's the best way to power some rear mounted driving lights? I am planning on putting a couple of HID driving lights on the rear that I can turn on anytime needed. Is there a good route to run power to the back or is there anything already run with the 7 pin towing plug?
Run the power wires somewhere out of site? I just ran mine when I had lights in the rear with the wires going down the inside of the passenger frame rail. But since your going such a long distance make sure to run a heavier gauge wire.
I'm not too sure of the 2011s, but I'd guess nothing would carry the amperage required for HIDs. You should do a fresh relay harness with a fuse.
35W HIDs will draw about 6 amps, so being safe use a 10A fuse. For under 15 feet, 12AWG is fine, anything over 20 feet will require 10AWG.
If you wanna have the room to expand with extra power, I'd run something like maybe an 4 or 8 gauge wire all the way to the back so you could just put in a distribution block to tap off of. Just an idea that would give you more power to expand with later!
x2. Good idea!
I was thinking about it you could basically just pick up a dual car amplifier wiring kit and use that, it would have just about everything you could possibly need to get it hooked up in there! I thinking there's one for sale over in the classifieds too right now..
