Whelen Hide-a-ways
Old Sep 26, 2011 | 05:09 PM
lightningx54's Avatar
Whelen Hide-a-ways
Any have a picture of where they drilled for the hole if you put whelen hide-a-ways in the reverse lights for the rear? its a tight fit on my 03. I want to put two to the head lights and two in the reverse lights.
Old Sep 26, 2011 | 05:36 PM
Pockets's Avatar
Are the 03 tails the same as the 07? I have Whelen Vertex in both my reverse and brake light housings ill take a pick for you if they are the same light.
Old Sep 26, 2011 | 06:45 PM
Raptor05121's Avatar
They are not the same as the 07s.
From the work trucks I have seen around here, they drill them from the bottom of the reverse light housing.
Old Sep 26, 2011 | 11:31 PM
it looked like it would touch the reverse bulb any place i drill it. I have to look at it better tomorrow. thanks.
Old Sep 27, 2011 | 12:56 AM
That wouldn't be a problem. The incandescent bulb gets hotter than the strobe does, and even then the heat transfer from one to another isn't anywhere near hot enough to worry about anything. You're only problem would be them bumping while going down a road. My road department uses them in 97-03 reverse lights so I know its possible, just look very carefully.
