Spyder LED's
Old Sep 19, 2011 | 03:29 PM
Coskid's Avatar
Spyder LED's
OK I am getting some replace lights for my truck in a smoke color and want LED's rather then the standard. I have seen prices ranging from $70-$175 for just the 3rd brake light and bigger areas for other lights. Spyder seems to be a nice light but it is always coming up cheaper then others. Has anyone purchased spyder lights before and have you been happy with the quality or is there another brand I should be looking into.
Thank you
Old Sep 19, 2011 | 03:48 PM
Raptor05121's Avatar
I have some Spyder lights and they are horrible. I ended up replacing them with my own LED array. The Spyder lights were dim and didn't fit right.
Old Sep 19, 2011 | 04:26 PM
pizzaman711's Avatar
Yea not the best quality ever, mine aren't nearly as bright as I expected. And if you go that route you'll need a tridon ep27 flasher relay too to get rid of hyper flash.
Old Sep 19, 2011 | 06:56 PM
Coskid's Avatar
Awesome this is the kind of stuff I need to know thanks guys. I want LED and I want smoke lens for my truck do you have a brand you would recommend.
Old Sep 21, 2011 | 09:11 PM
You might be able to pm raptor and see if he'll make you a set like his.
Old Sep 21, 2011 | 11:10 PM
Yeah I can put LEDs in OEM tails and black them out. Basically LED Harleys.
Old Sep 22, 2011 | 07:56 AM
Coskid's Avatar
I will look into that not a bad idea except still need to replace the third brake light as it is leaking.
Old Sep 22, 2011 | 10:14 AM
VerTDznS's Avatar
I have spyder heads and tails. Good enough for me. Sealed pretty good, no condensation. The tails fit like they were ment to be. The heads could be a little more tight but they still fit great.
