more light in reverse
Old Aug 6, 2011 | 05:09 PM
hardrock3742's Avatar
well I deliver pizza and i dont have a very good turning radius so im constantly backing up in tight spots.
I just picked up a pair of these http://www.autozone.com/autozone/acc...er=618333_0_0_
at autozone for 40 bucks. I heard that the bulb inside gives off yellow light so i was thinkign about buying replacement bulbs...maybe I could get some that are white but a little less powerful? and will the projectors have too concentrated of a beam ?
if they dont work out ill just give them to my brother for his excursion or just play doctor on them lol.
Old Aug 6, 2011 | 06:07 PM
Yellow is the opposite of black, you'll have more usable light with the yellow
Old Aug 6, 2011 | 06:26 PM
stick some 20$ fogs up behind the bumper and call it a day
Old Aug 6, 2011 | 07:04 PM
fdimeroller's Avatar
those projectors for $40 don't sound too bad... might look into this after you do it haha. i don't have reverse lights and i have super dark tint... bad mix
Old Aug 6, 2011 | 09:42 PM
2000FORDMAN's Avatar
Oh. I thought you meant projectors as in headlight projectors from the retrofit source. Yeah, yellow light offers more useable light.
Old Aug 6, 2011 | 11:09 PM
sweet, i may hook these up tonight. I think im gunna get a camera too because my lift leaves me with a big blind spot that is perfect for hitting mailboxes or low cars
Old Aug 6, 2011 | 11:10 PM
what kind of extension wire do I need to get it to reach my cab?
Old Aug 7, 2011 | 12:51 AM
installed the first one tonight, looks sweet. cant wait till the morning so I can install the other one and get some toggle switches. does anyone know what type of extention wire I need? it wont reach my cab since the lights are meant for the front.
Old Aug 7, 2011 | 10:03 AM
dsq3973's Avatar
Just make your own wiring harness out of either 12ga or 14ga wire and pick up some crimp on connections to match what is on the lights and switch. Also don't forget to use heat shrink on all the connections out side the truck or you will be redoing it all again.
Old Aug 7, 2011 | 10:40 AM
will 16 gauge work?
and the guy at autozone told me it was illegal to put lights on the back of your vehicle...is this true?
Old Aug 7, 2011 | 11:14 AM
dsq3973's Avatar
will 16 gauge work?
16ga is a little lite for that application, I always try and run a heavier wire to lights and especially if there is a long run between the power source and the lights like yours is going to be. I don't know if it's illegal in your state or not but it would not hurt to ask the local police and explain what you are doing with them.
Old Aug 7, 2011 | 12:09 PM
well I hit a roadblock. One of the lights is not working. I dont have it all hooked up yet but I wanted to make sure both lights work. one does but the other doesnt. unscrewed the light and the bulb looks fine and all of the connections look good. any ideas? I would just take it back but ive already messed with the other wires too much and i dont think theyd let me
Old Aug 7, 2011 | 12:23 PM
buy another set, swap out the broken one and return the second set
Old Aug 7, 2011 | 12:26 PM
atr04screw's Avatar
The guy at autozone was probably talking about blue leds that alot of people put on the bumpers and underglow and stuff like that. They always tell people that when they buy lights so that they can't be responsible for anything, but the way your using them shouldn't be illegal. When I first read your last post, I thought you meant you had literally hit a road block and broke the light haha. I always check my lights before I mount them by just touching the wires to the battery to see if it lights up. Make sure you have the switch wired the right way and all of the grounds are good.
Old Aug 7, 2011 | 12:30 PM
its weird tho. one light works even if the ground isnt touching anything but the other still wont work at all. blehh. I would but another and switch out the lights but the box has a security thing wraped around it and you have to basicly destroy the box to get it open.
