Moisture in reverse (but not break/signal) light?
Old Aug 5, 2011 | 10:38 AM
michrech's Avatar
Either my search-fu is terrible, or no one has mentioned this, so I thought I'd start a new thread.
I have a lot of moisture in the reverse light section of my tail lights, but it seems the upper/lower sections of the same housing is dry. I haven't actually pulled it apart yet (it's been hot as Hades outside the last several days), but I thought it'd be a good idea to see if anyone's encountered this, and if so, if there are some "typical" things that I can check to fix this issue.
Thanks guys!
Old Aug 7, 2011 | 04:54 PM
Raptor05121's Avatar
Check to see if the reverse light is properly secured
Old Aug 7, 2011 | 10:57 PM
canadianelbow's Avatar
The gasket for that bulb might be damaged or missing.......
