Switchbacks and 3ohm resistor question
Old May 7, 2011 | 02:43 PM
Darkness DT1's Avatar
Which wires do I connect the resistor to for the front turn signal. I don't have a multimeter to test the polarity of the wires.
Old May 7, 2011 | 05:25 PM
DanielWalker10's Avatar
im not sure on the wire, i will add my two cents though. just pick up a tridon ep-27 flasher, its a lot less troublesome over the resistors. i had two resistors go out but no trouble out of the flasher.
Old May 8, 2011 | 01:13 AM
thanks man!
Old May 8, 2011 | 03:17 PM
Which stock relay do I replace?
Old May 8, 2011 | 03:45 PM
Raptor05121's Avatar
the flasher relay under the dash
Old May 22, 2011 | 12:57 PM
Fox Fader's Avatar
If the EP-27 clicks sometimes when you hit the brake, don't sweat it. Mine does it.
Old May 22, 2011 | 07:07 PM
Thats not normal but okay
