2001 screw hvac issue help please
I searched through some old thread to try to find an answer but I might have missed somthing. I have a 2001 screw. Ac compressor is a little loud but it blows ice cold but when I give it a certain amount of throttle the blend door flips or somthjng and I hear the air rushing behind the dash. Any certain vacuum lines I should look for? I feel like when the engine draws or stops drawing x amount of vacuum it changes the doors position or somthjng. Any help would be very appreciated. Thanks on advance for any possible replies
You have a vacuum leak. Default position when vacuum is lost if defrost.
Check these common failure locations:
- There's a small vacuum tube that goes around the back side of your battery, these have been known to develop a leak.
- Also a small tube that goes through the firewall by the battery.
- Also check all the vacuum connections at the PCV valve.
I had a similar problem in an 03 SuperCrew 4x2. It turned out to be a cracked T fitting on the passenger side firewall. The third port on the T fitting was simply capped off anyway, so I removed it and straight piped it. I think that third port is there to run the vacuum shift motor on 4x4 models, I think it's where the solenoid gets its vacuum supply from. My truck, of course, doesn't have that so it was factory capped.
when I was having problems with my vacuum leaks on a 1996 fi50 4.9 , I tied the blend door actuator open with a zip tie so the AC worked through the summer while i troubleshot and fixed the leaks I also installed an aftermarket round ball vacuum reservoir going to the HVAC I don't know if your vac controller is in the open like the 96 is, but might help you temporarily,
