01 F250 Compressor notcoming on
So a few weeks ago we finally figured out why the compressor wasn't coming on. It was the clutch air gap. So it worked fine after removing a shim. It hadn't worked in a couple years. So for a couple weeks I had ice cold air. Last week I noticed it wasn't super cold and now this week no compressor and no air. I only use the truck maybe once a week. I checked today and the compressor clutch relay isn't picking. It's not the relay coil itself as I swapped it with the blower motor relay and still nothing. Any ideas?
Thank you!
Thank you!
You have to find out what the problem is first. Checking the high and low side pressures will tell you if the refrigerant is low. If it is low, I would just charge it and see how long it stays in the system. If it is leaking out, it could be leaking from one of many places, not just the compressor. If it needs to be charged, maybe add a can of refrigerant with the dye in it to help find the leak.
