radiator question
Old May 21, 2014 | 06:14 PM
grizzeyes's Avatar
radiator question
'96 f150 with 351 Windsor. if i have enough coolant in the rad, which when i checked the other day i could see it after removing the cap. i believe some rust might still be in there from draining a while back but should my water pump be ok if i have the right amount of mixture? Does anti-freeze really lubricate the pump's parts? Thank you
