Go Back  F150online Forums > Body > HVAC
2010 Lariat Right side blowing cold air >
Old 11-21-2013, 06:08 AM
Backnblack_66's Avatar
Having the heat on Auto or manual makes little difference.
Right side is blowing close to outside air temp.
Ideas on what to start looking at?
Old 11-21-2013, 06:15 AM
I'm guessing it's the blend door sticking or actuator is bad.
https://www.f150online.com/forums/20...side-help.html
Old 11-26-2013, 09:24 AM
Does anyone have the part numbers for the passenger side actuator and blend door?
Old 12-14-2013, 08:41 AM
Replaced the right side blend door actuator and all is well.
But i would like to meet the engineer that located it so i can thank him properly...lol
Old 02-22-2014, 03:00 AM
I have a 2010 also. Not a lot of info on where the actuator is located. My passenger side is blowing ambient air, neither hot nor cold. No popping sound or any of that. Where is the actuator located?
Old 02-22-2014, 08:03 AM
Behind and to the right of the Radio. You need to remove both the radio and glovebox. It also helps to have the hands of a child.
https://www.dropbox.com/s/e1q95b8dyg...20Actuator.pdf
Old 02-24-2014, 04:37 AM
Well that's better than pulling the dash. Thanks man
Hands of a child? Ugh my happening here.
Old 03-01-2014, 10:17 PM
Ok, here's an update. Thanks Backnblack for the PDF and instructions!
Went the route of pulling radio and glovebox.
Took 30 minutes to get all that out and the front screw of actuator out then 7 hours to get rear screw out!
GEEZ! Hands of a child is an understatement. But I duct taped a 5/16 wrench to my finger and after many curse words and cuts on my arm I got it out.
The blend door was fine.
Now I gotta get the screw back in for the new actuator.......I cut a 5/16 socket in half and welded it to the flat side of a long skinny screwdriver. I got my skinny armed wife to get the screw started. My socket rib was small enough to get between the actuator and that metal bar and was able to get everything back together in 30 minutes! I now have climate control again. $41....... Not bad
Old 03-13-2014, 10:54 AM
Glad it worked out for you..it is a PITA.
Old 05-20-2014, 04:15 PM
Blend door replacement - passenger side
Sounds like I need to replace the passenger side blend door actuator... could you send the PDF instructions again? Thanks!!
Old 05-25-2014, 07:03 AM
https://drive.google.com/file/d/0Bye...it?usp=sharing
Quick Reply: 2010 Lariat Right side blowing cold air
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
