AC/Heat Temperature Switch
Old Nov 29, 2011 | 11:43 AM
Flotown's Avatar
Recently, my temperature switch was becoming harder to turn from hot to cold. Last week as I was turning the ****, it broke off in my hand. The stem that the **** sits on broke all the way down to the tip so I can't even use some needle-nose pliers to turn on the heat. Now it is stuck only in the cold mode.
How can I change out the **** without having to take out the whole dash to get to it?
Can I just purchase the know from the dealership and install it myself?
Thanks,
Davis
Ford F150 - 1999
4.6 V8
Old Dec 29, 2011 | 08:40 PM
Yankee7985's Avatar
Yes, you can buy a replacement at the dealer and install it yourself. Once you get the part, you pull off the radio face-plate and you will have access to the rheostat.
