heating problems please help
Old Dec 29, 2011 | 09:58 PM
StevenHarlyD's Avatar
I have a 2002 Ford 150 HD and I can't get the heater to blow hot it is just warm at low fan speed when I turn to high it gets cool. I change themo and flush the system I have no blockage far as I can see. I upper rad hose is just harm not hot after I drive the truck for miles. What could be the problems. The electric water pump is pumping the coolent is cold.
Old Dec 31, 2011 | 10:48 AM
SETCHAN's Avatar
Build Tracking Moderator
I'd change the thermostat.
Old Dec 31, 2011 | 11:37 AM
Check the heater core hoses(careful they can be hot) they should be about the same temp....if not the heater core itself might be plugged.....
Old Jan 4, 2012 | 07:29 PM
jpressone's Avatar
I am having the same problem. I have changed the thermostat (which was bad enough). I hope it's not the heater core or the blending door, I have heard horror stories about both.
